Help Verizon s6 latest firmware?
  • Thread starter Thread starter godlovingman
  • Start date Start date
G
godlovingman
Guest
I've tried updating my Verizon s6 I thought it was updated to 7.0 but it won't. It'll go through the entire process but won't actually update keeps showing 6.0.1 and saying there's an update available.
so it will update and say update complete? no errors?
you can try manually:
https://www.sammobile.com/firmwares/
make sure that you have the correct model for your phone. flashing the wrong firmware could screw up your phone. also you will need a computer to do this. instructions on how to do this will be on the site where you download the firmware.
I wind up resetting the phone again and it updated to 7.0 but it keeps saying there's a new software update I keep clicking to install says it does but says there's a new software update every time after it restarts.
how often are you re-starting the phone? i rarely turn my phone off. and it is probably something you are going to have to deal with. you can try and get the latest firmware from sammobile.
The phone keeps restarting itself after each supposed update. I've done at least 5 different supposed updates and it'll restart and say there's another update available seems to be in and endless loop of supposed updates.
at this point you can either factory reset the device or flash the most current firmware from sammobile.
It shows it's running 7.0 in about phone so I don't understand why it keeps saying there's a new update.
