Sorry if this is a dead question now, but I'm having a lot of trouble with nfc and s beam on my phone. It's a verizon SIII sch I535 running stock 4.4.2, rooted. I bought it refurb, and I can't get the nfc or s beam settings to turn on.
The buttons move to the on position, but they dont turn green like they should. It just greys everything out so i can't even turn nfc off without restarting the phone. S beam can be shut off via the dropdown menu, if that means anything, but not nfc.
The battery is stock, says NFC on it. I've unrooted and factory reset, still no luck.
Any help would be VERY appreciated, since I've done all the research I could.
Thanks in advance..
Thanks in advance..
