Root [Verizon] (SOLVED) No 4G?
Have you flashed anything recently?
How long has this been going on?
Perhaps a temporary tower issue?
Did you change your settings recently?
What is ifes?:p
No flash lately...
Just noticed it today...
Wifey has same device and hers has no problem...
I meant "idea"! :p
Hmmmm, I be stumped :confused:
Have you tried to reboot?
What is your network mode set to? (menu/settings/more settings/mobile networks/network mode?
I know you meant "idea"....I just like harassing you:D
Indeed I have rebooted...
I'll check the network mode and get back to ya...
Sometimes, I hit the trigger before I proof read! :)
Here's a ss of the setting..
Yes I have BUT...
I figgered it out! My "Access Points" was not set to "LTE" :rolleyes:
Life's all good now. :D
Yes I have BUT...
How did that get changed?
It was on "EHRPD-Verizon Internet" before?
Glad you got it figured out!!:)
I think it would be helpful to others if you edit your thread title with the word (Solved) in front of the title.
I would do it for you but I would get fired:p
(nah, not really, but I am not allowed to)
Thanks Mike!
How do I edit the title to include "solved"?
Realy all I did was poked around in the network settings until I came across the one that I noticed was not set on LTE...so I just changef it and walah (I know, it's not spelled that way :D) it worked!
Hope it helps somebody else sometime :)
Edit your first post, tap Advanced, and edit the title from there. :)
PS - due to how the rules are set up, you can also request anyone on staff, including Mike, to do the edit for you, then it's okay. ;) :)
Must not be able to do it through TapaYak er uh I mean TapaTalk!
If I have your permission, I will do it for you:)
Most definitely Sir...you have my permission! But of course, we'll need to get all the legal documents drafted and determine a reasonable meeting location for the signing of said documents - preferably in Switzerland or Austria.
Just KIDDING :D:p:D
