D
Daniel
Guest
So I recently rooted my phone. That worked great. I also unlocked the bootloader. No problems there.
I also am using TWRP
I downloaded goo manager, and used that to find a cyanogen 10.1.3 stable. Downloaded that, and then launched restore mode (dont think thts the right name, it was holding vol up, power key, and home button)
So i chose install, and then went into goo manager folder and chose the cyanogenmod. Everything looked good. The device started to boot, i got the gs3 boot screen with the little blue cyanogen guy on it
And then it went to the cyanogenmod circle with the 2 rotating parts, and it was stuck there for about 20 minutes.
I found (on some other forum site) that someone else had a similar problem, and to fix it he simply pulled the battery and rebooted, so i did this. It has been stuck on the loading screen for about 15 minutes this time.. im not sure if i did somthing wrong, or if there is anything i can do to fix it...
please help!
EDIT: this is a verizon gs3
one more EDIT: Is this bricked?
please help!
