corvairbob
i have a verizon 10.1 tablet model qtair7. i only use it for monitoring my security cameras, but along the very top of the screen i'm always getting some type of notices. when you pull down the top of the screen and you get that drop down and in that under the time date etc those notices in the white background.
what i want to do is just turn them off forever. i wind up with hundreds in a week and that uses up memory and makes the table slowdown or even start using so much battery that it will not keep up and then shutoff
i went into the running apps and turned off every one of them for notifications, and i still get these.
so is there a way to just plain turn these off? i just do not need them for what this tablet is doing. thanks
