Root [Verizon] TowelRooted, now USB will not connect to Computer
laserbiz
I believe I need to remove TowelRoot to get my phone to function properly again. I really loved having towel root but somethings are not right about my Note3. This weird behavior started about a month ago. I had been using towel root without any issues for about 4-5 months|! I noticed that when ever I connected my Note 3 to any computer, the usb notification would not show up on my phone. It would charge but I had no way to access files on my phone thru any pc. Kies did not work and without USB I can't use Odin.
Also my phone would not ring or vibrate when I received a call. So I am looking to remove towel root and go back to stock in hopes that it would fix my issues, then hopefully reapply towel root to get back the functionality i want. I realize that I may not be able to get towel root to work again, and that is a chance |I am willing to take. but I need my phone to ring and get access via usb when I connect to any of my desktops.
The only items installed after towel root were the Xposed installer and the following modules:
Allow Long SMS
Blurred System UI
Enable Call Recording
Fake ID fix
GoSMS Module
HideNoPasswords
Instragram Downloader
Keepchat
Restore Input Method animations
Vine Downloader
Wanam Exposed
Wi-Fi--Pwd
So If I remove Towel Root would I be able to perform a factory reset with out any issues?
Any help would surely be appreciated!!!!
