[Verizon] TWRP Missing JB Compatible Mount Points
iwoloschin
I'm running XenonHD 6.0, with TWRP 2.2 as my recovery. When I try to install a new zip file via Goomanager, it fails, because TWRP can't find /storage/sdcard0, as that mount point does not exist under TWRP. I can see two solutions...
1) Goomanager is smart and translates mount points accordingly
2) TWRP has a bunch of symlinks, same as JB
I think Option 2 is the best, but I'm not sure if anyone else is seeing this problem. I might try opening up the TWRP image later and figuring out how to add a symlink to the /sdcard mount point, shouldn't be hard, but I'm kind of surprised this hasn't already been done...
I had this issue with flashing JB roms through goo manager with twrp. I even tried doing it manually by booting into twrp and telling it step by step what to do and it fails by just stopping the installation and rebooting the recovery.
