The module repository is here:
Welcome to the Xposed Module Repository! | Xposed Module Repository
If you click on the word "XBlast" in my previous post, it will take you to that particular module.
Do you already have the Xposed framework installed? Modules will not work without it.
I assumed you already have the framework installed, but just makin' sure
If not, here is the link for the Xposed framework:
Xposed - General info, versions & changelog - XDA Forums
Usually, a module will have its description/compatibility listed at the download page.
If you are in question about a paricular module, just post back here
Oh, one more thing....some modules can have conflicts with each other. In other words, if Module "A" changes the clock to the color blue, and you have Module "B" set to turn the clock red...well, there's a conflict.
So be sure which modules do what.
The XBlast module has alot of options in and of itself and that's why I only ran one module
Edit:
another popular module for our devices (S3) is
Wanam ..check it out
