I'm running Liquidsmooths 1.25 ROM and haven't been back to check for updates since I loaded. I see that 1.4 is out now. Can I just load that on my SD Card and run it or do I need to uninstall 1.25 first?
There's nothing to uninstall: that's your operating system.
By flashing a new ROM over the old one, you're effectively replacing your phone's OS. And considering that you're several versions of Liquid behind, I would recommend a wipe before flashing it.
