PLEASE READ IF YOU'RE WORRIED ABOUT BRICKING WITH ROOT/ROMS.
Hello all... first time post. Not at all new to Linux, and been doing 'hoodrat things' on android phones for a couple years. Not the best in the universe, but I can hold my own.
I picked up a S3 today from Verizon after gaming the system to keep my unlimited data plan and had some issues I wanted to share with you all... as it's EASY TO 'BRICK' THE PHONE. (IMO)
So there's two ways to root now that most folks are seeing if you dig up info.
1) The little .bat file you run, no Odin needed.
2) Flashing on a rooted stock (bloat free or full) with Odin.
Talking about them...the first seemed to work fine for SU, but I was having wifi tethering problems. So I grabbed some .zips and went "old school" in ROM Manager. BAD idea.
So backups seemed to go fine. I tried to flash over a rom, and everything went to hell. It started to boot, then locked me out of recovery and EVERYTHING but download. I got a nice message from the Verizon police saying that they detected unauthorized software on the device, and to go to the store immediately.
Screw that. You know how this story goes, no one is going to be like "hey look, I got the phone and did all sorts of crazy things and it broke!" I went to some rather... well... quasi-trustworthy sources and got a copy of the bootloader, pit, pda, etc.
I did manage to get the phone back to stock, and then put on the rooted bloat free OS with Odin. Too much removed, don't like it. But with the rooted through Odin, wifi tethering seems to work a-ok.
Back to the Rooted bloat-full rom and am manually cleaning it up.
My tips- (obviously if you're a rock star, you can use your judgement and do whatever. =)
Use Odin, bloat FULL rom, and clean it up yourself.
DO NOT TOUCH THE BOOTLOADER.
DO NOT TRY FOR QUESTIONABLE ROMS (yet)
Right now... it seems with this bootloader crud Verizon is pulling it's very easy to put yourself in a real bad spot with being locked out.
If it DOES happen, you CAN fix it in Odin. But if you're worried about rooting and new to the game... keep it simple. A normal "stock rom" will not solve the verizon police issue. You pretty much have to go through getting the full phone back to "normal."
Get Odin, get a stock rom with root. Again- keep in simple unless you are pro.
I'm also seeing that Rom Manager backup SEEMS to work... but restore does not. YET AGAIN- keep it simple if you're a new user. The 'old' ways of doing stuff aren't hammered out on Verizon's version just yet.
Time will allow folks to get around all these troubles... but since it happened to me I wanted to share the thread and let you know if you do get this warning... you CAN FIX IT.
Feel free to ask me how, we can chat and I can provide links and such needed... but I would rather not post some of the places I had to obtain things from on the forum. (Hope you guys understand.)
Cheers!
Cheers!
