AOKP or Code Name Android?
Also, which kernel should I download to go alone with each one?
Better is really a subjective thing and the answer you will get will be purely that person's opinion
My suggestion would be to try both and see which you prefer. Also try different kernels to check them out. The two most popular kernels seem to be leankernel and franco, but there are a slew of them out there!
Personally, I love AOKP. I'm running b26 along with the 2.2.0 LeanKernel. But that's just my preference, the only way you can answer your question is to try them and see which you find better![]()
Is it easy to switch from ROM to ROM? If you can explain how please.
i prefer codename, but i understand why others like AOKP. switching between ROMs is fairly simple. download the ROM .zip file, boot into clockwork recovery, wipe data/cache/dalvik, and then load the .zip file you just downloaded. more detailed instructions can be found here:
http://androidforums.com/3736602-post10.html
also, i am moving this to the all things root section.![]()
I see, thanks. I want to update to the latest android version, and then I want to load codename...I don't see the clockwork recovery app on my AOKP app as I didn't install the AOKP rom correctly, it missed the gapps file. Do you know how I can do this, should I first get the ROM in or the new android version in for verizon LTE?
if you are going to load codename/AOKP, there is no sense in loading 4.0.4 first. codename/AOKP are currently based on 4.0.3, and upon flashing them you would lose any of the changes made by loading stock 4.0.4.
I've just said exactly this in another thread. There are about a dozen threads scattered across the GNex subforums, all started by this same person and asking basically the same questions.
to get into clockwork recovery, power down your phone, then hold volume + and - while powering on. once it has booted to the green android screen, scroll with the volume arrows until you see "recovery" then press power to select. if clockwork is installed correctly, you will now have a menu that looks like this:
Can someone please help me find the link to the latest Codename Android ROM and the latest Leankernel?
Thanks!
Are there major differences between Codename and AOKP? There aren't any clear-cut features lists for them, I just find a bunch of people liking one or the other more. I used CA for a few days and have been using AOKP for a few weeks now.
The whole dev community is scattershot, I wish there was more organization and explanation, rather than a lot of "try it and see." :/
