Root [Verizon] Xposed installer issue
kdoudman
Any reasons why I wouldn't be able to install the "xposed installer" on my G2? I'm on the Verizon version, 4.2.2, rooted. I open the apk and I get the typical apk install screen. I scroll to the bottom and there are "cancel" and "install" options. I click on the install button and nothing happens (it doesn't even "press in"), but I can click the cancel button and it closes the install. I've tried three different versions of the xposed installer and I still can't get it to work. Could there be something, like SU, restricting the install? Seems odd to me.
If you're installing a downloaded apk, make sure to allow installation from "unknown sources" at Settings > Security.
Thanks iowa, finally figured it out though with some help from guys over at xda. It was something much more "complicated" than that. I had a screen filter on (twilight), and that was putting an object right where "install" button is such that the button was under that. Once I turned the filter off, I was good to go.
