Help Very weak UMTS signal, losing data connection, GMS works fine
lampak
Hi. I've got a problem with a Droid 3. GMS works fine but when I enable UMTS I get a very weak signal, around one bar. Mobile data sometimes-somewhat works but keeps disconnecting constantly.
So it gives me a choice between terribly slow but reliable EDGE and fast but fussy 3G. Neither of them is a compelling option :/
It's not a carrier issue, other phones have full strength in the same area.
Has someone here had a similar problem? Do you know of any solution?
heres a fix to the problem
Wrong UMTS signal indication on XT862 [Fixed!!!] - xda-developers
download ES File Explore,go into the \system\ directory and change the line in build.prop
