Viber on PC
wally9
I have been using viber for quite a while on my android phone and have been quite happy with it. Recently I installed viber on my pc and initially it worked but after that each time I would try to use it on pc it would keep asking if I had it installed on phone. It then took me through to play store where it showed it as installed. But no further facility to actually use it on pc. I uninstalled other devices on play to avoid confusion but made no difference. I would appreciate any advice or observations.
Thank you in advance.
I don't know what you did wrong. I installed it on my PC. Then it took me to Play and I installed it on my phone. A couple of codes later and it's running on both of them.
Thanks for replies, I did follow all the steps and initially set it up on my phone, which works fine, The problem is that it now won't set up properly on my pc, insisting that it is not set up on my phone which it is and has been for a long time. I don't know what to do here.
