viber problem with calls on wifi
Hello people, I have a problem with Viber when on wifi, can not receive calls but only gets notifications for missed calls when i unlock the phone. On mobile data all works nicely. Do you have an idea how this can be solved? Messages are doing nicely on both Viber and WhatsApp.
I figured out the problem. Solution: set phone's wifi sleep policy to turn off the wifi when phone goes to sleep, and then in Viber's wifi sleep policy put option to always keep wifi on. That's how i solved my problem and now calls are comming just like messages.
Hello, thank you for saying I knew the solution the same thing happen several times.
Nothing man, but unfortunately it lasted for me 2 days and now again problem. I figured out another solution, install wifi timeout app from Google store, then set it to 0 sec, in WiFi sleep policy put option to disable WiFi when screen is locked. Also do this in Viber.
Then ur phone will use 3G (mobile data) when its locked, and push notifications will arrive on time, and when u unlock it it will use WiFi. That's now solution that works for me good.
another solution is to just install advanced wifi lock and problem is solved. it is problem with rom, it shuts down wifi when phone goes to sleep.
