A Android Question Guest Oct 3, 2013 #1 How do you control or change viber sounds ? The sound is very irritating every time I receive or send a message
girolez Often Off Piste Oct 3, 2013 #2 Hi Open viber menu more options settings tick the "use system sounds" box You should then get the notifications from your default messaging app (and ringtones from phone) Roger
