I used to have an option giving a small vibration when outgoing call established, i just dial the number and hold the phone normally and when the call establishes it gives that vibration. i had it on windows mobile 6
It depends on the phone. With the ROM I'm using it's controlled by a setting in the "call settings" menu. On a different model there's a sub-menu "call alert" in there, which is where it can be found. Conversely I've found threads from some phones where the feature is turned on but apparently no control to turn it off! So I suggest having a good poke through the call settings menu to see whether it is in there somewhere.
If not, there are apps in the market/play store for this. I've not used any (as have the feature) so can't really recommend one. A search for "vibrate on answer" or similar on Google Play or appbrain.com will find a few though.
