I have had the s3 mini since September, and other than a few battery problems, it's been fine.
Recently, I have been experiencing vibration problems. It worked perfectly normal, then it had completely stopped working. Every couple of minutes or so, the vibration will be VERY vigorous. It is quite annoying as there isn't much damage that has been applied to the phone.
Aswell as this, the vibration also started working perfectly fine last night, although it was only for half an hour.
