Video Review - Seido Vault - Charging on the go!!!
I cant watch the video since I'm at work, but does it mention how long the charge will last?
You mean how long it holds a charge? If so I presume it is no different than a spare battery, meaning it will keep its charge.
I mean, how many charges can you get from this, and how much battery life does it "add" to the battery? How long will it be until I have to charge it again?
I can not imagine this is any different than a battery in your phone. I am not a battery expert, but my guess is as many times is your cell battery.
Not sure I am following you on "does it add any battery life". It simply charges your devices battery. Hence if you have the Vault with you and you are running low on your device, you simply plug the Vault and device together and the Vault will charge your phone. If you have a 1600 mAh battery in your device, this should completely charge your device. If you do indeed fully charge from the Vault, you will have to recharge the Vault via the wall adapter.
On same page now? If not let me know where I am not understanding you.
