Help video streaming problems
Hi
for the past week Ive been having trouble streaming video from any website that dosent use you tube
it seems to have started when I got rid of google chrome due to the fact the tabs kept flashing at me.
I switched to firefox for its flash ability and installed the flash apk
since that time 9/10 times when I try and play a video that in chrome would open up mx player I either get stuck on the loading sign or get an error video cannot be played
This is all on various sites that I have never had a problem with before
so heres what I tried
using another 3rd party video app was using mx player tried mobo,flv any player I could find recommendations for -same result
using different browsers used puffin, dolphin amongst others same result
going back to google chrome still same result
uninstalling flash reinstalling flash
going back to original configuration
using the stock video player and browser
Ive even tried playing the same stuff on my wifes s3 with no problem
Does anyone have any idea of a fix? Any help would be appreciated
I just switched from a Razr Max which played flash just fine, so when I got this phone I was somewhat miffed that I cldnt get flash to play on this phone! However a few days ago I downloaded a flash browser called Flash Fox, its a spin off of Fire Fox, but tweeked to stream flash better, and so far it has been working great! Hope this helps!
Not sure what sites your trying to view/stream from, but 3gp is typically a video file extension that cell phones use when they record videos, thats not a flash flv extension
