Help ViewPad 7 sd Card and openSuse 11.2
nobellium
When pad is linked to openSuse 11.2, it seems that the pc doesn't recognise sdcard.
From /var/log/messages, I got:
Apr 13 21:57:26 linux-zd0x kernel: [26420.888316] usb 1-3: SerialNumber: FM6111020141
Apr 13 21:57:26 linux-zd0x kernel: [26420.888454] usb 1-3: configuration #1 chosen from 1 choice
Apr 13 21:57:26 linux-zd0x kernel: [26420.889797] scsi29 : SCSI emulation for USB Mass Storage devices
Apr 13 21:57:26 linux-zd0x kernel: [26420.890188] usb-storage: device found at 26
Apr 13 21:57:26 linux-zd0x kernel: [26420.890191] usb-storage: waiting for device to settle before scanning
Apr 13 21:57:27 linux-zd0x kernel: [26421.890731] scsi 29:0:0:0: Direct-Access GOOGLE Mass storage ffff PQ: 0 ANSI: 2
Apr 13 21:57:27 linux-zd0x kernel: [26421.890958] sd 29:0:0:0: Attached scsi generic sg1 type 0
Apr 13 21:57:27 linux-zd0x kernel: [26421.891477] scsi scan: INQUIRY result too short (5), using 36
Apr 13 21:57:27 linux-zd0x kernel: [26421.892327] usb-storage: device scan complete
Apr 13 21:57:27 linux-zd0x kernel: [26421.893973] sd 29:0:0:0: [sdb] Attached SCSI removable disk
Any ideas why I can't see the sd Card?
Thanks
Exactly the same problem here with the Viewpad 7 connected to Ubuntu LTS 10.04
Jul 1 23:37:32 earth kernel: [21352.150065] usb 1-8: new high speed USB device using ehci_hcd and address 13
Jul 1 23:37:32 earth kernel: [21352.302427] usb 1-8: configuration #1 chosen from 1 choice
Jul 1 23:37:32 earth kernel: [21352.303071] scsi13 : SCSI emulation for USB Mass Storage devices
Jul 1 23:37:37 earth kernel: [21357.300854] scsi 13:0:0:0: Direct-Access GOOGLE Mass storage ffff PQ: 0 ANSI: 2
Jul 1 23:37:37 earth kernel: [21357.301210] scsi scan: INQUIRY result too short (5), using 36
Jul 1 23:37:37 earth kernel: [21357.302181] sd 13:0:0:0: Attached scsi generic sg9 type 0
Jul 1 23:37:37 earth kernel: [21357.316065] sd 13:0:0:0: [sdi] Attached SCSI removable disk
Jul 1 23:38:15 earth kernel: [21395.436872] usb 1-8: USB disconnect, address 13
Linux earth 2.6.32-32-generic #62-Ubuntu SMP Wed Apr 20 21:52:38 UTC 2011 x86_64 GNU/Linux
Someone can help us please?
When I mount the 32GB mSD card in my card reader it works. So it is Android and/or the viewpad who is boring.
Jul 1 23:55:00 earth kernel: [22400.647360] sd 4:0:0:0: [sdd] 62333952 512-byte logical blocks: (31.9 GB/29.7 GiB)
Jul 1 23:55:00 earth kernel: [22400.651990] sdd: sdd1
I umounted it, deleted the partition, made a new partition with a fat32 f.s. on it. Put the card back in the viewpad, connected the USB cable, same error: scsi scan: INQUIRY result too short (5), using 36
For the moment the workaround seems to be to umount the mSD card from the viewpad 7 and insert it in the pc card reader. blech.
Is this pbm experienced more? Someone can help please?
ok, I am very new with android and a tablet phone. When I plugin the USB cable in my Ubuntu PC and I go back to the viewpad I see 2 usb messages. One is about debugging and the second to choose is to CONNECT to the PC. And yep. selecting this gives me a nice file manager over the inserted 32GB mSD card. The viewpad shows a red robot telling I am connected and have to umount on the PC before to continue here..... Thinking about it, this is logic.... case closed. Thanks.
