D
Deleted User
Guest
I have just been given a new VPad7. Its brand new. Problem is it wont connect with internet via my home router (Livebox). I have checked with viewsonic who just said connection was all automatic so long as ssid was right. I double checked that and it is. Apart from that they said all they could suggest was a reset of the Vpad and router. I've done that and it didnt work. It connects to wifi through hotspots no problem and I have a PC and laptop running off the router OK. Supplier has since suggested that the router needs to be reconfigured, so asked Orange who just said a reboot might fix it. (it didnt). Has anyone had this problem before? If so whats the answer??? I'm thinking it must be settings in the router but I dont want to muck up my other connections just trying to fix the tablet. Any help would be appreciated! Cheers.
