mqureshi79
Member
Alrightey, so I had the infamous android.process.acore problem. Here's what I did that fixed it and wanted to share.
Symptoms:
- turned on tab, acore error started popping up every few seconds
- no access to keyboard
- no access to settings
Thing's I didn't do:
- hadn't installed anything new right before this happened
- didn't adjust adw settings
- didn't install a Facebook update
- didn't do anything with contacts -its my tablet, not my phone I.e. no contacts
Thing's I tried that didn't work (not in this order):
- uninstalled fbook
- uninstalled adw
- updated to tntlite 2.4 (I was on 2.2)
- rebooted a bunch of times
- talked sweetly to it and bought it chocolates. .. nothing.
- reflashed roms
- ran permission fix in rom manager
What did work:
- reinstalled vanilla OS
- accepted ota upgrade and updated (was then able to get to settings)
- did hard reset
- re-flashed tntlite 2.4
- lost my settings and some downloaded apps, but sdcard files still there (pics/movies)
- reinstalled rom manager and ran permission fix (corrected 100% battery problem)
I'm just an amateur, so I'm not sure which one of these things worked, or if I even approached this right. Just know when I was researching a fix there was a lot of frustration out there and not too many real solutions (someone even claimed it was because of ATK, which wasn't true for me coz I don't use it).
Anyhow, hope this helps someone out there who was experiencing the same thing.
Cheers! MQ
Symptoms:
- uninstalled fbook
- uninstalled adw
- reflashed roms
What did work:
- did hard reset
Cheers! MQ
