Viewsonic V350 Dual SIM Android - currently on 2.2.
Just needed to know if anyone else has this phone? and uses it with an in-car blutooth system? as this phone is good does everything it is meant to do - but when you use in-car system either through sterio or voice dial it seems to hang and not dial. I have since found out that the phone is expecting you to unlock it and choose which SIM you want to call from!? I need a work around for this - or a default SIM to use when on hands free? cannot find this setting anywhere. Works fine for incoming calls no problem accepts calls on both SIMS as active/active - but cannot use for outgoing calls... anyone help?
