Help vignette camera
arkangeluk
Just dld vignette and can't find pics is there a way to put them into the 3d gallery as I have a shortcut set for it. Thanks if anyone can help
ric
3d gallery will automatically scan the entire SD card for all media. If you have taken fotos and saved them, Vignette saves to its own folder by default, but the Gallery will see it. If it dosent restart the phone or the app and it should be there. You can also tell vignette to save all to the default camera folder ie DCIM which for sure 3d Gallery looks in always.
Yeah thanks, restarted phone then realised pic hadn't been saved that's why the gallery didn't see it all ok now
ric
