Root villainrom 2.1 random reeboots and fc
toddyc
I have the 2.1 villainrom and everynow and again it will reboot or fc qpps any ideas on how to stop this or should try a dif rom ?
before you installed it, did you do a full wipe? dalvik, data before you installed villain rom 12?
Which rom did you have before VR12?
have you installed any and all ota updates?
Villain12 is pretty stable, as ROMs come. Random FCs are more likely to be caused by corrupt downloads. You might want to try re-downloading the firmware and flashing it on your phone (only a wipe of the dalvik cache is needed, so you wont loose any data).
In future you might want to use a program like 'md5sums.exe' to find out the md5 checksum off the file you downloaded. If it matches the one listed on the ROM download page you know you have the exact same file without any corruption.
