villian rom 3.0 help
i need help i made a previous thread about this in the wrong section im sorry =[ im trying to close it atm
but here is my problem i have flashed villianROM 3.0 on my print samsung galaxys2 and now
1. i have no baseband and wifi
2. my sd card wont show in my phone
3. my home and menu button wont work. instead search acts as menu but back still works as it should
this is what i did
1. i rooted my phone and put CWM on and did a backup
2. wiped data/factory reset
3. wiped cache
4. install zip from sd card
5. installed villianROM 3.0
6. rebooted
where did i go wrong?
Seems reasonable to me.
do you still see your imei number in settings>about phone>status
if not, then your efs folder may be stuffed.
if you do see it then you should be ok
I would firstly try flashing a modem. See here
if this fails, then perhaps try flashing the villain zip again.
If that fails, try downloading+flashing it again.
if that fails, then restore from your cwm backup and give up!
