Root [Virgin Mobile] Access Mobile ID?
rickyx32
I'm not sure what happened, but when I bought my S3 months ago I was able to gain clear access of Mobile ID app, but now on a new S3 I bought yesterday I am unable to access the app after it installed all the crap apps and wallpapers... The first thing I did was root the device, so I don't if that had anything to do with it? The app seems hidden, is there any way to use it again?
What are you trying to do, make the Mobile ID app install all those crap apps and wallpapers again? I'm pretty sure that's all it does and you can't access it again. If you want it to do all that stuff again, I think the only way is to factory reset your phone and/or flash a new ROM (either stock or punkmaxx's).
Not that I want to keep or "use" it, its just that back in the earlier S3 release I was able to access Mobile ID to uninstall the bloat pretty easily... Does anyone know what APK to extract from the stock ROM or any way to prevent the Mobile ID update from installing on a fresh install?
