Root [Virgin Mobile] Android 5.0 Lollipop Messaging "Messenger" APK
axelxbc
Member
Figured I would post this here after giving it a try for a little while. Stumbled into it yesterday when trying to find the stock android MMS application. This will indeed work perfectly on Android Kitkat 4.4.4, I do not know of other versions it will work on so install at your own risk if it is lower then Kitkat 4.4.4.
File Download:
https://dl.dropboxusercontent.com/u/45195962/Messenger .apk
Enjoy! :D
Works great, but when trying to attach a picture, the app force closes
It was trying to use the wrong resolution for the picture (apparently nexus will be capable of sending at full resolution). But here is a fixed version, thanks to moonknightus.
fixed lollipop messenger
It will not install over the original version because he had to sign it with a debug key so if you have the original, uninstall it first!
Thanks again moon. :cool:
