Root [Virgin Mobile] Another option besides CM 10.1
timbck2
I had CM 10.1 on my S3 and everything worked fine (besides LTE) but I just didn't care for it (though it's certainly better than stock) so I started looking for another option. I decided to try the Sprint build of LiquidSmooth 2.9 since that's what I run on my Nexus 7.
It works great! I don't know about LTE since I don't live in an area that has it, but everything else does. I also had to flash the MMS/voicemail fix that I modified from someone else's fix for a different Virgin phone (I can't remember which, but my fix, in which I merely fixed the mount points for the partitions) can be found in the CM 10.1 thread.
Ive been using this rom for the past 5 hours and its really really nice. I dont have 4g at my house but when i drive around i should get it.
I've been running this rom for a few weeks and can confirm that lte does not work. When lte is turned on and your in a area with lte you loose all data. Great rom though
I use wicked sensations. The only real issue I've had so far is use quick dial causes the screen to go black and it won't come back on. Have to reboot the phone. Don't know if 4g works or not, don't have it in my area.
redrunner1985,
Did you flash Wicked Sensations from the Sprint S3 without changing the mount points? Also does mms works?
I'm also just waiting for something to come out that has 4g working. I get 4g all over the place in my city and I like using it.
