Root [Virgin Mobile] anyone could figure to turn camera sound off
TronXiix
Does anyone recognized that stock camera make Sound off button for camera to be taken. I wonder if there way to put it on silenced? If anyone know how to do it. I tried third's application apps from market but stock camera more quick. More reliable
Yeah, Camera360 works ok and has no sound, but its a fairly rough app that has no panorama mode and is a bit annoying to use. I love the stock camera, but the only way to make the sound go away is to root your phone.
Already rooted I'm just having trouble getting shutter noise off. I went on the link and can't get the password to work :/
What exactly are we supposed to do in there? Do we just delete a file or something? I'm trying to shut off the sound also.
i edited the feature.xml file under camera there is a line about shutter sound changed it to the opposite setting and now have a menu option in the camera apk took a reboot and you need root. fix permission to rwx,rwx,rwx used es file explorer.
Using root explorer you can do this-
1. browse to system/csc
2. open feature.xml in a text editor. (With root explorer hold down on the file and choose open in text editor.)
3. Under the line "CscFeature_Camera_ShutterSoundMenu>false</CscFeature_Camera_ShutterSoundMenu."
Change "false" to "true."
Save and exit. Reboot your phone and under camera settings just under Anti Shake you will have the option to turn it on or off.
There's now an option to turn off the camera sound in the latest update samsung sent out. Just navigate to the camera and go to settings and it should be there.
If you are rooted then you can enable the shutter sound menu item by adding
Code:
true
to /system/csc/feature.xml (or changing false to true if it isn't already there).
This worked for me and is the easiest method without having to delete any system sound files. This enables a menu in your camera settings which can easily be enabled or disabled as seen here :)
EDIT: Ahh several people beat me to this.
My apologies, I should have looked a little harder before posting ;)
