Root [Virgin Mobile] Anyone know of a development site for MIUI for VM GS3
You can try the sprint version. Make a nandroid first. I haven't tried it. You'll need to fool around with MopedRyder's sprint to vm fixes. They may give you MMS, or LTE, but probably not both at the same time.
MIUI
MR's mods
Don't flash the fix, it won't work. If you flash the sprint version of miui(the latest one) you will get 3g. Haven't tested MMS but I know for a fact that 3g works UNTIL you flash either fix, and it then breaks and no more data.
