moonknightus
For anybody who used Kies to flash a Sprint ROM to their Virgin Mobile phone, fix for you to test.
Flash it in recovery, then restore a stock ROM.
Can't say for sure that this will fix the issue as I have never tried to flash a Sprint ROM to my phone. It's essentially a shot in the dark, but basically I've taken a DD dump or an available raw image of most mmcblk0 partitions on the phone and placed them into an updater script which writes the raw images to the appropriate partitions.
Be careful with this as it flashes partitions that are not backed up by TWRP and as such cannot be easily restored, so don't try it until you've tried everything else first!
If you want to see which partitions exactly are being overwritten, just pull apart the updater script. I tried to make it as descriptive as possible.
Good luck.
Baseband Fix V2
Good luck.
Baseband Fix V2
