peter counias
Yes carbon kit Kat is up over on xda development if anyone wants to give it a try! I'm going to try it in little while I let youse know how it goes!
is there muti windowed??Just installed it. So far, so good. I get a force close whenever I try to open device tunables under system settings, carbon fibers. Other than that, everything seems smooth and fast. I like the lockscreen options, and the pocket mode.
I installed with MopedRyder's APN fix 2, PA's kk gapps, and the qualcomm optimized dalvik patch.
4g and MMS work perfectly.
The carbon threads force closes and adding shortcuts to lock screen does not work but otherwise IT IS SO COOL! I can not wait for a stable release. I have no plans of changing this build as mms works and 4g works with fix 2.Just FYI, these are unofficial builds. The Carbon team has not yet started releasing official builds. Let us know how good these builds are, can't wait for the official versions!
No multi like on OMNI ROM
Still random reboots when using the camera??
