yorkcommatyler
So I seem to be completely screwed, but I'm hoping that I can be told otherwise. :/
Virgin Mobile SGV, and I'm trying to have it activated over at Straight Talk. Everything finally worked on their end, all I needed to do was dial ##72786# to get to the SCRTN menu and reset my network settings (I assume), but nothing showed up in SCRTN, just a blank black screen.
I figured since I was rooted with a custom ROM that if I reset to factory and followed the TWRP stock image restore method, I'd be in the clear to try again. It won't let me post a link to the thread, but a little ways down there was a post from JerryScript that involved wiping the "system" files as well. The problem is this:
Now I have no OS, and TWRP won't let me mount anything, internal or external. I've plugged the microSD into my pc to format it with a 128mb EXT4 and 0mb swap, but still nothing in the SGV. From the TWRP middle button's console screen I see "E:Unknown File System: 'datamedia', and everything I do in TWRP now fails. I'm using TWRP v2.6.3.0 if that helps, and I can provide any other necessary details. Hoping against hope it's not too late. Thanks in advance!
EDIT: I should mention, I can still use TWRP's File Manager fine, which is remarkably confusing.
