Root [Virgin Mobile] [DEV] VM SGS3 Mount Point List (...Finally!)
punkmaxx
Okay Boys and Girls after much research and and little elbow grease I've managed to get all of the mount points for our phones.... THIS IS USEFUL!!!​
Mount Points....
FULL LIST:
Mount Point Start End Size File-System Name
_____________________________________________________
/dev/block/mmcblk0p1 4194kB 67.1MB 62.9MB modem
/dev/block/mmcblk0p2 67.1MB 67.2MB 131kB sbl1
/dev/block/mmcblk0p3 67.2MB 67.5MB 262kB sbl2
/dev/block/mmcblk0p4 67.5MB 68.0MB 524kB sbl3
/dev/block/mmcblk0p5 68.0MB 70.1MB 2097kB aboot
/dev/block/mmcblk0p6 70.1MB 70.6MB 524kB rpm
/dev/block/mmcblk0p7 70.6MB 81.1MB 10.5MB boot
/dev/block/mmcblk0p8 81.1MB 81.7MB 524kB tz
/dev/block/mmcblk0p9 81.7MB 82.2MB 524kB pad
/dev/block/mmcblk0p10 82.2MB 92.7MB 10.5MB param
/dev/block/mmcblk0p11 92.7MB 107MB 14.3MB ext4 efs
/dev/block/mmcblk0p12 107MB 110MB 3146kB modemst1
/dev/block/mmcblk0p13 110MB 113MB 3146kB modemst2
/dev/block/mmcblk0p14 113MB 1686MB 1573MB ext4 system
/dev/block/mmcblk0p15 1686MB 14.8GB 13.1GB ext4 userdata
/dev/block/mmcblk0p16 14.8GB 14.8GB 8389kB ext4 persist
/dev/block/mmcblk0p17 14.8GB 15.7GB 881MB ext4 cache
/dev/block/mmcblk0p18 15.7GB 15.7GB 10.5MB recovery
/dev/block/mmcblk0p19 15.7GB 15.7GB 10.5MB fota
/dev/block/mmcblk0p20 15.7GB 15.7GB 21.0MB ext4 carrier
/dev/block/mmcblk0p21 15.7GB 15.7GB 6291kB backup
/dev/block/mmcblk0p22 15.7GB 15.7GB 3146kB fsg
/dev/block/mmcblk0p23 15.7GB 15.7GB 8192B ssd
/dev/block/mmcblk0p24 15.7GB 15.8GB 5243kB grow
DO you wanna Dump your partitions? Need to know the file name formats and command syntax? Well.... Here ya go!​
adb shell
su
dd if=/dev/block/mmcblk0p7 of=/sdcard/boot.img
dd if=/dev/block/mmcblk0p14 of=/sdcard/system.img.ext4
dd if=/dev/block/mmcblk0p17 of=/sdcard/cache.img.ext4
dd if=/dev/block/mmcblk0p16 of=/sdcard/persist.img.ext4
dd if=/dev/block/mmcblk0p18 of=/sdcard/recovery.img
dd if=/dev/block/mmcblk0p1 of=/sdcard/NON-HLOS.bin
dd if=/dev/block/mmcblk0p5 of=/sdcard/aboot.mbn
dd if=/dev/block/mmcblk0p2 of=/sdcard/sbl1.mbn
dd if=/dev/block/mmcblk0p3 of=/sdcard/sbl2.mbn
dd if=/dev/block/mmcblk0p4 of=/sdcard/sbl3.mbn
dd if=/dev/block/mmcblk0p6 of=/sdcard/rpm.mbn
dd if=/dev/block/mmcblk0p8 of=/sdcard/tz.mbn
so this method isn't right. .? I found it on the xda forums.
using terminal emulator I typed.
su
lk0p7 of=/sdcard/modem.bin bs=4096
exit
exit
su
exit
exit
what that will do is look at the file what the posted op info will do is copy them to the root of your sdcard.
