Root [Virgin Mobile] Flash Virgin Mobile update on Sprint S3?
payterx
I have a Sprint Galaxy S3 that i'm using on Virgin Mobile. Because of this, I would like to flash the Virgin Mobile KitKat update through odin. Would that cause any problems? I know they're the same phone internally but I don't want to brick it.
Also, MMS have never worked on it, and none of the MMS fixes for Sprint S3's flashed to VM have worked, so I was hoping that flashing the VM update instead of the Sprint one would change something that would make it work.
Thanks
EDIT: I guess what i'm trying to ask is, If you flash a Virgin Mobile KitKat update through odin, would later flashing the Sprint KitKat update through odin brick the phone? Would it brick because it would have to flash another bootloader?
Yes... You can flash your L710 Sprint phone with the VM Kitkat Odin flash.
If necessary check the APN settings.....
