Root [Virgin Mobile] get back stock recovery help
hilla082
cant seem to find a specific download for my device s3 with nj3 baseband what im asking is how do I get back my stock recovery as I need to return everything to stock any help would be appreciated thanks
There is no full return to stock for nj3. You can Odin the nj2 sprint tar if you want. It works.
so odin the nj2 wont brick my phone? cool then I can update back to nj3 right? I didn't do that cause I thought it would brick good to know thanks
If you go on nj2 theres no way to get back to nj3 not until someone takes the stock rom and makes a flashable zip out of it then you'd be able to flash back to nj3
No nj2 is the sprint version of nj3. It won't brick you though, it will put you stock sprint, which works just fine.
