Welp my Victory had Victorius ROM on it and I never did a backup. The system is gone. I was on my way to restore it back to stock but it just hangs and I have lost TWRP. I get the boot .img for Victorius and it hangs/ I have tried using ODIN and I have the Samsung drivers installed and I try to flash over TWRP but I do not get the blue box that says "Added". I have all the necessary files on my sd card but I think that it is toast ie the phone. Let me know if you have any guidance. I have the recovery roms/images on the SD card. I just can't get TWRP or CM flashed so I can restore it.
Thanks
All of this is my own fault
Thanks
