Root [Virgin Mobile] Help pleaseeeee
a week ago I flashed CM10 with all the correct steps, i got rid of it today because I like to take pictures and I Couldn't do that in CM10. For some odd reason on the stock rom, I can't view my gallery because it says my sd card is not detected... :mad::mad: . Can anyone help me out???:confused::confused::confused:
Can you access your SD card through the file manager?
Were you set up for the int/ext swap at any point?
