Does anyone know how to recovery virgin mobile boot animation?
Install custom rom and then recover back to my rooted stock rom. The only thing is missing is virgin mobile boot animation. Its just blank but you still can hear the noise.
if you delete the files you would need to load a copy of them to the correct spots with the correct perms or you can simple dirty restore a backup over it and hope. if you renamed the file.bak then rename it back to what ever the match name is. the media file for video should be in system/media/video or something like that.
