Root [Virgin Mobile] Liquid Smooth Cannot activate data.
D
Deleted User
Guest
Well I updated liquid smooth, flashed the latest one, and now it won't activate the mobile data, it sits there for 10 + minutes and never activates, or has a message popping up about com.android.phone has stopped working, I've tried reinstalles, reboots, everything I can think of. Can anyone think of anyone else to do?
Happened to me. First you install the ROM. And you must flash MopedRyders MMS fix :) I use MOD 3.5 and I use hangouts for MMS.
http://androidforums.com/showthread.php?p=6153524
Mine took forever to activate, and it either finally did or just timed out and moved on, but I had data. I also got the android.phone stopped working error repeatedly the first time I installed, but I just kept hitting Ok until I was able to reboot the phone and it worked fine after that.
