jrccomputer
I can't understand why my antu scores are so low. It says that my gs3 is lower than a gs3. My score is 15887. It should be higher.
ah i see. The 10471 I posted was from a month or two ago, I just had a saved screnshot. I just ran it again and got 15666.BTW a score 10000 or so is horrid for an S3 considering I get higher scores on the S2 and Victory...
Edit: Looking deeper into it, scores also vary depending on which version of antutu you have. I've only used antutu v4 on the S3 and normal scores should be around 15k for a stock SPH-L710. I remember scores would vary wildly every other release of antutu v3 on my other devices.
Don't feel bad. My score is 15521
Benchmarking really is just a number used for bragging rights. If the phone is responsive enough for your needs and runs smooth performing day to day tasks I wouldn't worry about the score.
Did you notice in the benchmark results that our device is a beast at 3D graphics when compared to the Galaxy S3 and Galaxy S4? It's on par with the Nexus 10 in that department![]()
