Root [Virgin Mobile] Massive Battery Drain on rooted stock TW 4.4.2! Why?
Piznick64
Ive done everything possible! black wallpaper turned everything off (wifi) disable google now stuff (ok detection) and also with s-voice! i went to developer options and did 4 processes, custom kernel, debloated, brightness as low as possible! GPS off still getting like a few hjours battery. With my c-rom i was getting 18+ hrs now im lucky to get 3 why?
hmmm. odd, not thinking it will help much. However, it wouldn't hurt for you to actually ODIN the NDC which was intended for the VM version.
Also, I would throw Philz back on it and just do a full wipe (prepare it for a new rom), even though ODIN is suppose to clear everything. I would just do that first and then ODIN the NDC to see if you get better luck.
I read that there is a camera bug in 4.4.2 that causes severe battery drain to some users. If you goggle 4.4.3 you will see it listed as a fix.
This may not be your problem but might be worth looking at.
There are a few battery draining Samsung apps. Freeze or uninstall them and that should sort you out.
Just Google safe to remove touchwiz galaxy s3.
I had this problem when I first got my S3 and put Cyanogen on it. After a little digging I found out it was a known issue with the EMail app, even when it's not even configured. I used Titanium Backup to freeze it and everything's been fine since.
So glad it was such an easy fix...I would've had to get rid of the phone otherwise.
