Root [Virgin Mobile] MidnightRom:GS3 JB 1.0.4 9/1/2013 Supercharged stock
Need help now!
I can not get recovery to work! I install everything and use Odin but when i try to boot back into recovery, after it is still stock recovery, no install from USB, no storage, nothing!
Did you pull the battery after flashing the recovery. once you flash via odin and flash was successful unplug usb cable and pull battery must do this before booting up the phone
Battery icon change can be done with Rom Toolbox. I don't know if we will see any updates for this rom or not.
So I used Rom Toolbox but it only replaced the battery icons that were 10,20,30 etc. other than that, the charging and battery intervals such as 98,98,97 etc are the icon Dakman ported.
A bad dl maybe? This rom is based off of stock vm rom, so all should work as it did on stock. What all have you flashed/done?
Let's see, when I got my GS3, turned it on. Logged in and did the change phones option from the VM website. And then I rooted using the method from this thread and then I downloaded the MidnightROM and flashed the zip.
Some VM s3s were in fact originally sprint s3s. They just flashed new software to make it virgin .. I experinved this when i had a hardware issue and had to have my virgin s3 replaced by virgin...they sent me a sprint s3...it was reworked for virgin but it WAS originally sprint....when i factory reset the replacment phone...all the virign apps coverted to sprint...the my account icon changed right infront of my eyes to the sprint zone icon when i tapped it...if u got it from the virgin website this is probably your issue...flashing mopedryders apn fix for tw(the all in one didnt work) fixed the same problem when I experienced it..
So you're saying I should flash mopedryders apn fix? I actually ordered my GS3 from HSN lol. If I made a backup of my phone and flashed the fix and didn't fix, I could restore and get the original apn I had before correct?
Apn Backup and Restore from the Play store can back it up.
I can't find a link for the apn fix. Can someone link me?
EDIT: nevermind I found it lol.
EDIT 2: Arrgh. So I was able to back up my APN but I can't restore it cause it said something about not being able to restore on 4.0+. Also, I flashed MOD #1 of MopedRyders. It took forever to get the data to work but right now. Only 3G is working. I can't send MMS to myself :S.
EDIT 3: Okay. I got the old APNs back. But here's a thought. Does anyone have the original APNs from the stock version of this phone? I specifically remember 4G actually working for me before I flashed this Midnight ROM.
