Ab5traktion
I found this while searching for d2spr Android 4.4.2 ROMS. Technically, it's for the CandyKat ROM. I tried the ROM for almost an hour but the GPS didn't seem to work and that was a huge no-no for me. So, I decided to see if it would work with other ROMs, and it does. I've used it with every d2lte/d2spr ROM I've flashed. I've been having a lot of fun with it, since you can make the 4.4.2 ROMs look the way you want it to look. Create your own experience.
I should say that I've been using the Sweetner Pack 1 V2.2 but there is a Sweetner Pack 2 V2.4 for more Navigation Bar Mods. Not sure if you can dirty flash this or not. I've been clean flashing this after flashing the ROM and GAPPS.
The Mods with this available with this include:
- LockRings
- GlowDotz
- Custom HALO
- Scrubbers (volume|media handles)
- LockMax
- Wifi Icons
- Signal Icons
- In-Call Icons
- LockScreen Targets
- Clear All Icons
Candy Sweetner Themes and Mods: Themes and Mods - Welcome to The Candy Shop
- LockRings
- GlowDotz
- Custom HALO
- LockMax
- Wifi Icons
- Signal Icons
- In-Call Icons
- Clear All Icons
