Hi guys, I'm having some trouble here and did do lots of reading before finally deciding to post. Maybe I missed something?
I think I resolved the brick issue and now I'm just running into the problem of finding a ROM to put on this thing. I'm able to flash Sprints ND8 4.4 with obviously no data or sms but I can not find a stock VM ROM. The ones I did run across were .tar and they would either fail or say "MD5 hash value is invalid". Ive tried factory resets from the recovery and it always ends up in just hanging at the "Samsung Galaxy S III" screen.
Ive been at it for almost 6 hours and would greatly appreciate any info!
*Update*
As I said before, Sprints ROM works with only data being the issue. Which affects mms unless I'm using wifi. So is there a fix to get the data to work?
*Update*
