Root [Virgin Mobile] Need Help
iTransform
I have a soft bricked Galaxy Victory, I got TWRP recovery on it but it will not mount to my computer. Will someone please upload the stock rom in a .zip format so I could save it on the SD card and flash it?
If you look in the threads below in this forum you will find what you are looking for. 100% stock. Just look for the link called vmobi browser in the post , and select the TWRP.zip from there.
Here is the post.
http://androidforums.com/virgin-mob...-mobile-victory-05-19-2013-a.html#post5790639
take note though! this appears to be a backup not a flashable zip.. in other words.. unzip it and use TWRP to RESTORE it! Don't flash it.
Here are the magic posts explaining it from that thread:
05.13.2013
Created backup of the stock ROM which can be restored through TWRP.
All this has changed from a flashable zip to a backup that needs to be restored using TWRP. It works perfectly and is 100% stock with no info on the ROM. I listed a Q/A in the OP. Just got tired of fighting the flashable zip, it would load but the radio would not work. My time will be better used on CyanogenMod anyways, I just wanted to have a 100% stock something for everyone to roll back on if need be.
As always enjoy :D
Download the TWRP.zip file from the OP, then extract the zip. Take the folder it creates and put it on your SD Card. Boot into TWRP and then got to restore and choose External_SD and restore. 187 seconds later you should have a booting device :D
