Ok, I currently own a VM GS3 I had it rooted after the purchase then wanted it unrooted just because...
I flashed a sprint rom on accident phone still worked fine just had a sprint bootload and required an SIM card
I proceeded to reroot and flash the stock zip from this forum and it worked but Clockwork was still there and my phone was still rooted
I then proceeded to try many other ideas none of which worked I then tried the flash counter reset and this is where things got bad
I no longer have any service except calling VM I have bars but thats it (well and Wifi) I also have all the sprint stock apps even after flashing the VM kernal
I need help trying to fix this I have run out of ideas and places to find anything for the VM GS3
My about phone is as follows
Model SPH-L710
Android version 4.1.2
Baseband L710VPAMD7
Kernal 3.0.31-1154085-user
se.infra@SEP-66 #2
SMP PREEMPT Sat Aug 20 07:15:45 KST 2013
Build number jzo54k.l710vpamd7
hardware version L710.14
Status
Network Samsung
signal -81 dBm 8 asu
Mobile network EvDo-rev.A:8 (this is because i turned off 4g which I dont get period)
Service state in service
user name 99000344259630@hcm.sprintpcs.com
mobile network state connected
my number is all zeros except the last 4 6224
Min is the same as above
PRL version 31104
MEID are viable will type if needed later
IMEI are visible will type if needed later
ICCID are visible will type if needed later
Device status modified (after flashing theBrittons roms)
Edit: I can flash the reset counter to get my looking stock
Model SPH-L710
Baseband L710VPAMD7
se.infra@SEP-66 #2
Status
Network Samsung
PRL version 31104
