Ok I'm really confused now I'm currently on cm 11 because of the wifi issue I can flash the stock rom no problem how do I check my modem version though
Idk how to check it, but you can flash the MK5 modem to make sure that's the one you have. If you flashed the MK5 update from the link above, you should already have it.
